(vba)how to get graphic info from a comlex entity
i am working on a essay that requires calculate the floating state of a specific ship,i had managed to loft the boat into a "autocadloftedsolid".but i need to "intersect" the boat with another box(return the part that below water line) for 100 times in oder to find
(if boat.volume*density="part that below water ".volum*density)
its water-line and calculate the mass point and floating force point .(i also need to rotate the boat for 20 times,thats 100*20=2000times:o)
Is there any way to return the information that we can get from the command "massprop" automaticaly or simply convert "autocadloftedsolid" into "3dsolid"since i found the ".volume" function in "3dsolid" class.Or is there a way to do it in lisp.
i have a silly way but the speed is far from satisfaction
Sub calculus( m() As Double, v As Double, boat As Acad3DSolid, div() As Integer, dele As Boolean)
Dim pmax As Variant
Dim pmin As Variant
boat.GetBoundingBox pmin, pmax
Dim lx As Double
Dim ly As Double
Dim lz As Double
lx = (pmax(0) - pmin(0)) / div(0)
ly = (pmax(1) - pmin(1)) / div(1)
lz = (pmax(2) - pmin(2)) / div(2)
Dim p1(2) As Double
Dim cent(2) As Double
Dim mtemp(2) As Double
Dim vtemp As Double
Dim bt As Acad3DSolid
Dim box As Acad3DSolid
On Error Resume Next
p1(0) = pmin(0)
p1(1) = pmin(1)
p1(2) = pmin(2)
For kk = 1 To div(2)
For jj = 1 To div(1)
For ii = 1 To div(0)
cent(0) = p1(0) + lx / 2
cent(1) = p1(1) + ly / 2
cent(2) = p1(2) + lz / 2
Set bt = boat.Copy
Set box = ThisDrawing.ModelSpace.AddBox(cent, lx, ly, lz)
p1(0) = p1(0) + lx
bt.Boolean acIntersection, box
If Err.Number -2147418113 Then
vtemp = bt.Volume
mtemp(0) = mtemp(0) + vtemp * cent(0)
mtemp(1) = mtemp(1) + vtemp * cent(1)
mtemp(2) = mtemp(2) + vtemp * cent(2)
itemp(0) = itemp(0) + vtemp * cent(0) * cent(0)
itemp(1) = itemp(1) + vtemp * cent(1) * cent(1)
itemp(2) = itemp(2) + vtemp * cent(2) * cent(2)
If dele = True Then
bt.Delete
End If
Else
box.Delete
bt.Delete
End If
Err.Clear
Next
p1(0) = pmin(0)
p1(1) = p1(1) + ly
Next
p1(0) = pmin(0)
p1(1) = pmin(1)
p1(2) = p1(2) + lz
Next
i = itemp
m = mtemp
v = boat.Volume
End Sub
