thesniper
AxisCopy2
thesniper
you can use this macro to make multiple offset with different distances, you have to enter all distances and then select an entity and specify side to offset
to install it, paste the 2 files in C partition, use load application command in AutoCAD to load the Lsp file and type "ax" to run it
Any comments are appreciated
Thank you
Mostafa Abdo
AxisCopy2.zip
Share this post
Link to post
ReMark
Has anyone here scoped out this macro?
Share this post
Link to post
Tiger
Thank you
Mostafa Abdo
Mostafa, If you are looking for comments and feedback on this I would recommend that you post the code as just text here, wrap the code in code-tags (
 , [\code]) and it will look good anyway.
It's all about making it easy for the customer to access your code.
Share this post
Link to post
thesniper
the code for this command is very large about 200 lines, so it is hard to publish it I just want everyone to use it and report me does it work good or have any bugs.
Thank you in advance
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
