Hello All....
I am new to this forum and I am in hopes that someone here can shed some light on this Metric problem I am having. I have worked in Imperial units my entire career (25+ yrs) and had very little to no need to use Metric units. I now find myself in a position that I need help with....I have a drawing that I am trying to create....and here's what/how I did it....in Model Space I created my graphics with my Units set to decimal and unitless, that way they can be anything I want them to be (or at least this is waht I was told many years ago)....I created my drawing, no problem....now I have flipped into paperspace to create the layout tab for this drawing. I have my paper size set to 8.5 x 11.....and I am trying to scale my viewport to a metric scale, not sure exactly what that scale will be just yet....anyway....as I have been doing some reading on the internet concerning the scale factors for metric viewports I am finding all kinds of confusing info....I have found charts that show the scale factors are as simple as 1:100 (1/100xp) and then another chart shows that the scale factor for a 1:100 would be (10xp) so am I missing something here? I found an article that speaks of the fact that in paperspace the viewport would be scaled to millimeters instead of meters as in Model space.....so needless to say I am more confused now than ever.....I took a look at the standard viewport scales that come embedded inside Acad, and based on what I have read from my research, Acad doesn't provide any standard Engineering scales as I see it....for if you look at the scales like 1:10 it shows 1 unit in paperspace is equal to 10 units in model space....well based on the chart that I found, that would reflect a Metric scale, as the same chart shows that a 1"=10' Engineer scale would be 1 unit in paper = 120 units in model....so again...I am sitting here with smoke now seeping out of my ears...due to a mental overload with this...trying to figure this thing out....so if any of you could/can provide me with a list of scales that I can add to my scale list that would give me the correct parameters for both my engineer scales as well as the metric scales I would forever be humbled.....I am just so confused at this point.....HHHEEELLLLPPPP
Thanx...Anita:cry:
Scale is expressed, for example, as being 1:100, 1:200 or 1:1000. Zoom factors, for example, are expressed as 10xp, 5xp or 1xp.
ReMark....
Can you please explain to me how you got the 10xp, 5xp, etc.....this is all making no sense to me whatsoever.....and my only excuse is I'm having a Monday! I so want to understand the metric viewport demon, but at this point in time I am just lost.....I am now confused about the scales that show up in my scalelist.....the 1:10, 1:20, etc scales...are they metric or are they engineer? I have read that the engineer scales are as follows.....1"=10' (1/120xp not 1/10xp) I know that I am sounding really dense here, but I am just lost.....:shock:
I really am in hopes that someone can provide me with the scales that I can place into my scalelist and have them just come up when I select the viewport scale list....or at least provide me with the correct formulation for calculating these factors.....
Thanx again for you reply....and I apologize for being thick as mud today!
Anita
:wacko:
The scales 1:100, 1:200. 1:250, 1:500 etc. are metric.
Calculating zoom factors. In AutoCAD these are denoted via the
"xp" option of the Zoom command.
Remember that a millimeter is 1/1000 of a meter.
Scale: 1:100 Zoom factor = 10xp
1/100 x 1/1000=
1/100 x 1000/1=
1000/100 = 10
Scale 1:200 Zoom factor = 5xp
1/200 x 1/1000=
1/200 x 1000/1=
1000/200 = 5
Scale: 1:250 Zoom factor = 4xp
1/250 x 1/1000=
1/250 x 1000/1 =
1000/250 = 4
Scale: 1:500 Zoom factor = 2xp
1/500 x 1/1000=
1/500 x 1000/1=
1000/500 = 2
From DraftingSteals.com:
"Metric floor plans are drawn in a ratio of 1:50. This is very close to a scale of 1/4" = 1'-0" (1:48 )."
