make a selection set with all lwpolyline and circle
  • Replies 27
  • ectech
    11
  • wizman
    8
  • Lee Mac
    6
  • MSasu
    3
Thank you very much for your help Lee and wizman.
I'm try to use this lisp to draw a ellipse but got some problem. how to drawing a ellipse by lisp and can I use the bpoly to make the circle or ellipse ? thanks !
Here's for Circle thru bpoly:
(defun c:CPoly (/ cen ent i ss)
 (vl-load-com)
   (if (setq i  -1 ss (ssget '((0 . "CIRCLE"))))
   (while (setq ent (ssname ss (setq i (1+ i))))
     (setq cen (vlax-get (vlax-ename->vla-object ent) 'center))
     (vl-cmdf "._bpoly" "_a" "_B" "_n" ent "" "" cen "")
     (entdel ent)
Ellipse to Polyline by Fuccaro:
http://www.cadtutor.net/forum/showpost.php?p=14416&postcount=16
 (vl-load-com)
     (entdel ent)
Thank you very much for your help ! you are my lucky star !!
That's a good start for the day,.:) Thanks Ectech.
I'm trying to use the ellispe to polyline lisp but it is only convert to polyline, it is possible to convert to lwpolyline ? I'm thinking can I use this lisp convert to polyline first and then use the bpoly command convert it to lwpolyline, but after convert the ellispe to polyline, I can't get anypoint inside the polyline. Is there other method ?
Thanks !
