I want to rename a block with VBA.
I need to rename a titleblock with attributes (e.g. A1 or A2 or A3 to VX_TITLE).
I don't want to use:
ThisDrawing.SendCommand "_-rename" & vbCr & "b" & vbCr & "A1" & vbCr & "VX_TITLE" & vbCr
Who can help me?
I've done this recently but I'm home right now with bad weather. If nobody comes along before the snow melts I'll check how I did it.
OK, thanx. Tomorrow, they expect a lot off snow here (Kampen, Netherlands) also and they are running out of salt.....
sounds much the same here. I can get to within about 2km of my work on main roads - no problem. BUT the final bit is up a single track lane. I don't want to drive an hour to there and then find I can't get in so I still don't know if I'll try today or not.
OK, this is what I did...
gpCode(0) = 0 'item
gpCode(1) = 2 '?
groupCode = gpCode
dataValue(0) = "INSERT" 'item type
dataValue(1) = "STL*" '?
dataCode = dataValue
Set mySelSet = ThisDrawing.SelectionSets.Add("Blocks")
mySelSet.Select acSelectionSetAll, , , groupCode, dataCode
For Each myItem In mySelSet
If UCase(Left$(myItem.Name, 5)) = "STLA1" Then BlockName = "H:\Design_Office\E343\Blanks\E343T-A1.dwg"
If UCase(Left$(myItem.Name, 5)) = "STLA2" Then BlockName = "H:\Design_Office\E343\Blanks\E343T-A2.dwg"
If UCase(Left$(myItem.Name, 5)) = "STLA3" Then BlockName = "H:\Design_Office\E343\Blanks\E343T-A3.dwg"
If BlockName <> "" Then
   Set x = ThisDrawing.ModelSpace.InsertBlock(BlockPos, BlockName, objScale, objScale, objScale, 0)
   x.Delete
   myItem.Name = BlockName
   BlockName = ""
   End If
Next myItem
all our drawings should have a drawing frame called STL* so I create a selection set of all the block instances just in case somebody has more than one frame inserted. There SHOULD only be one though!
I then decide what the new name is going to be based on what is already in the drawing. I then create an instance of the block to be inserted. Note that I don't insert it into the drawing, just prepare it.
and finally I get to the line where I rename the existing block! I would think you should be able to do the selection set and then rename it. Give it a try!
ok, you gave me an idea to solve my problem.
The title block needs to be the same name: VX_TITLE, whether it is a A0, A1, A2, A3 or A4. Other applications look for a title block called VX_TITLE and uses its attributes.
I'm thinking about creating different directories named \A0, \A1, etc.
Then using code like yours and change BlockName to e.g. "c:\A0\VX_TITLE.dwg", "c:\A1\VX_TITLE.dwg", etc. Off course in each dir it's a different title block.
I try to test it this weekend.
There must me a easier way. At the command prompt it's so simple (-rename)
Isn't there a simple method or whatever in vba?
Thanks,
Marco
there may well be a simpler way, I stumbled upon my way when I was working out how to replace the existing block with a new (renamed) definition so it worked for me. Keep us posted with your progress as I am sure I will need something similar soon.
For what I was doing, my way actually saved me a couple of expected steps so I was pleased! :)
Still snowing over there? We have had a small fall overnight and a few flakes this morning but nothing of significance. More is expected tonight though.
Found it!
Dim objBlock As AcadBlock
For Each objBlock In ThisDrawing.Blocks
  objBlock.Name = Replace(objBlock.Name, "A3", "VX_TITLE")
Next
In the south its snowing, here it's still dry. The kids have a lot off fun with ice skating now.
Marco
well done :) I'll see if I can remember it when I need to.
Ice skating on lakes or rinks?
Thanks,
They skate on rinks, small canals, lakes in forest and on the edges od greater lakes. But the ice is not so good because of the snow.
Have a nice weekend.
Marco
