Bill Tillman Posted January 10, 2010 Posted January 10, 2010 I'm not sure if this is a problem or not, but in attemping to unload a custom lisp program I seem to have unloaded everything. When the dialog box for cuiload came up there were several items in the list. I clicked on CUSTOM and then clicked unload. I seem to have double clicked instead of single clicked and now when I open up the cuiload menu the list is completely empty. This is the same even when I exit AutoCAD and restart it. Did I do something wrong here and if so how do I correct it? Quote
Darin.Green Posted January 10, 2010 Posted January 10, 2010 I'm not sure if this is a problem or not, but in attemping to unload a custom lisp program I seem to have unloaded everything. When the dialog box for cuiload came up there were several items in the list. I clicked on CUSTOM and then clicked unload. I seem to have double clicked instead of single clicked and now when I open up the cuiload menu the list is completely empty. This is the same even when I exit AutoCAD and restart it. Did I do something wrong here and if so how do I correct it? To get everything back, use menuload or cuiload and select the ACAD.cui file. The ACAD.cui should load the default cui files, which includes CUSTOM. To remove CUSTOM from the list, type CUI and hit enter. Under "Customization in All Files" expand "Partial Customization Files" right click CUSTOM and choose "Unload CUSTOM.CUIX". Click OK to close the CUI interface. Quote
