Hey there was hoping some could give me a little advice.
I have generated a 3d model of a building in autocad arch. 2008 and i am about to import this in to Autodesk VIZ 2008 to render the building up. I was wondering if it would be easier to add lights in auto cad arch as i seen an option for it there or would it be better to add them in the VIZ package?
Cheers for any help.
bertsquall
I've never used Viz, but there is an option in Max, in the import dialog, for including lights with the import. But, since the whole reason for importing to Viz is to set up your scene for rendering, you may as well set up your lighting there, rather than in Autocad. But as far as which one is easier? Everything is easier in Max.
