OMEGA-ThundeR Posted January 11, 2010 Share Posted January 11, 2010 Hi, In a dynamic block i want to make a point grip, and i attach a 'Move' command to it. Normally it would say if i want an offset or multiplier, but now after i selected the objects that are binded to the point the command ends. Is there an way to get those options back? I can't find it in the properties or in the Block Authoring Palette. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 11, 2010 Share Posted January 11, 2010 The information you're looking for is covered in your AutoCAD Help files under the heading Use Distance Multiplier & Angle Offset Action Overrides. Quote Link to comment Share on other sites More sharing options...
OMEGA-ThundeR Posted January 11, 2010 Author Share Posted January 11, 2010 http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffa23ce210c4a30acaf-6d2e.htm,topicNumber=d0e80143 Thats the url, and i guess the same as the help in autocad (my helpfile seems missing ). But i do what it says, i can't find anything like that in the properties palette.... Edit: Aaaahaa! Found it. I had to click on that icon wich represents the action and THEN it shows the 'overrides' in the properties . Thanks. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 11, 2010 Share Posted January 11, 2010 Sometimes it is easy to overlook the obvious. It's even easier to overlook the not-so-obvious too! LOL You're entirely welcomed. Glad you got it all straightened out. Quote Link to comment Share on other sites More sharing options...
