flyingjunkie Posted January 12, 2010 Posted January 12, 2010 This has only happened in one drawing so far, but when I draw a polyline, the line is empty instead of solid. I've tried FILL, Tools>Options>Display>Apply Solid Fill, Lineweights>Display Lineweights, amongst other things. Any advice on this issue would be greatly appreciated. Quote
ReMark Posted January 12, 2010 Posted January 12, 2010 Did you type REGEN after making the change noted above? Quote
flyingjunkie Posted January 12, 2010 Author Posted January 12, 2010 Yep. (Lesson I learned the hard way early on lol) Quote
ReMark Posted January 12, 2010 Posted January 12, 2010 The last time I helped someone with a similar problem I passed along this which comes from AutoDesk: "If the fill still does not display, it is possible that the UCS in modelspace is not parallel to the UCS where the polyline was created. If the polyline was created in the World UCS for example, on the View menu, click 3D Views > Plan View > World UCS." The other possibilities are that Shademode is set to either 3Dwireframe or Hidden. Quote
flyingjunkie Posted January 12, 2010 Author Posted January 12, 2010 The World UCS worked for me. I would have never thought of that. Thanks a ton for your help. Quote
ReMark Posted January 12, 2010 Posted January 12, 2010 You're entirely welcomed. Glad your problem is no more. Quote
flyingjunkie Posted January 12, 2010 Author Posted January 12, 2010 One more quick thing if you can help. Is there a way to align the World and Modelspace UCS? When I print to limits now, I only get the top corner of my drawing Quote
ReMark Posted January 12, 2010 Posted January 12, 2010 Did you move the UCS from its origin of 0,0,0? Have you tried UCS > World? Quote
flyingjunkie Posted January 12, 2010 Author Posted January 12, 2010 I didn't do anything like that. But the problem I'm working with is that I'm dealing with a drawing that was previously done by someone else (hence the problems I'm having). I'm just doing revisions. It printed fine before I did the World UCS thing that you told me about earlier, now it's only printing the top right corner of my drawing. I've tried resetting the limits, but to no avail... Quote
ReMark Posted January 12, 2010 Posted January 12, 2010 When you plot, under Plot Area > What to Plot? tell us what is shown there. Is it Limits, Display, Window or Extents? Quote
ReMark Posted January 12, 2010 Posted January 12, 2010 You did this right? Set UCS to World. Run the PLAN command, press twice. Quote
ReMark Posted January 12, 2010 Posted January 12, 2010 I plot to Limits Did you check your Plot Offset settings for both X and Y? Quote
flyingjunkie Posted January 12, 2010 Author Posted January 12, 2010 I did, but it still doing the same thing... Quote
ReMark Posted January 12, 2010 Posted January 12, 2010 Would you be willing to email your drawing to another forum member so they could take a look at it? It has to be something simple that is just being overlooked. Quote
flyingjunkie Posted January 13, 2010 Author Posted January 13, 2010 I can email the title block, but that's it. The drawing is company sensitive info. Quote
ReMark Posted January 13, 2010 Posted January 13, 2010 The titleblock and border right? Maybe leave in a couple of the polylines that caused your first problem? Quote
flyingjunkie Posted January 13, 2010 Author Posted January 13, 2010 The TB and border are there, as well as some plines. Other than that, the drawing is blank. But I did check to make sure that the problem still exists and it does. Print size is 24x36 Landscape if you can mimic that. Is there a place I can email it to tho? The forum max file size is 250KB and I'm at ~750KB Quote
ReMark Posted January 13, 2010 Posted January 13, 2010 Answer me this...have you also purged the file? Quote
flyingjunkie Posted January 13, 2010 Author Posted January 13, 2010 No. The layers and styles aren't anything noteworthy, so I figured I'd leave as much as I could the same so when I go back into the actual file, I can be sure that as much is the same as possible. Quote
