Alminate Posted January 12, 2010 Share Posted January 12, 2010 Hello All, I’m having an issue with curved mass elements. It seems that a vertical line is placed wherever there is a point on the Pline I used to create the mass element. The curves become even more jagged when I have a mass element that is based off of arcs. I'm attaching a .pdf of my drawing that shows this. I'm using ADT2006, I understand that there is an option in newer versions that take care of this, is there anything I can do with my version? Thanks, AL Fire Guide LP-FCA 45-01.pdf Quote Link to comment Share on other sites More sharing options...
MarvinX Posted January 13, 2010 Share Posted January 13, 2010 Hello All, I’m having an issue with curved mass elements. It seems that a vertical line is placed wherever there is a point on the Pline I used to create the mass element. The curves become even more jagged when I have a mass element that is based off of arcs. I'm attaching a .pdf of my drawing that shows this. I'm using ADT2006, I understand that there is an option in newer versions that take care of this, is there anything I can do with my version? Thanks, AL Try options->Display->Draw silhouetes for solids and surfaces.It will definately reduce your problem to a few vertical lines. To eliminate the completely...i don't think you can. And i would be very interested to point out the option in the newer versions that you mention! Quote Link to comment Share on other sites More sharing options...
Alminate Posted January 13, 2010 Author Share Posted January 13, 2010 I don't see that option in my version, am I looking in the wrong place? Quote Link to comment Share on other sites More sharing options...
MarvinX Posted January 13, 2010 Share Posted January 13, 2010 You're at the right place...It's the "Show silhouetes" and it is checked. The results that you posted are with this option ticked? Quote Link to comment Share on other sites More sharing options...
Alminate Posted January 13, 2010 Author Share Posted January 13, 2010 I didn't think that was the option because it said "Show silhouetes in wireframe," but yes, the posted drawing was created with my options setup as shown above. Quote Link to comment Share on other sites More sharing options...
Noahma Posted January 14, 2010 Share Posted January 14, 2010 if they are Mass elements, use the command AECFACETDEV and change it to something less than a 256th inch. And then it will show smooth. You might need to set the variable first, then recreate the object. Mass elements do not do curves, they segment it all. The command above allows it to divide the "curve" into many more facets. Quote Link to comment Share on other sites More sharing options...
