Hi,
I have this VBA macro which sort imports data from a text file.
I do not know exactly how to make it good.
I have two sheets, named
On sheet I made a command button with this code:
Private Sub CommandButton1_Click()
' Macro1 Macro
' Macro recorded 2/17/2008 by Hack
   With ActiveSheet.QueryTables.Add(Connection:= _
       "TEXT;H:\MyPath\test.txt", _
       Destination:=Range("A1"))
       .Name = "test.txt"
       .FieldNames = True
       .RowNumbers = True
       .FillAdjacentFormulas = False
       .PreserveFormatting = True
       .RefreshOnFileOpen = True
       .RefreshStyle = xlOverwriteCells
       .SavePassword = False
       .SaveData = False
       .AdjustColumnWidth = True
       .RefreshPeriod = 0
       .TextFilePromptOnRefresh = False
       .TextFilePlatform = xlWindows
       .TextFileStartRow = 1
       .TextFileParseType = xlDelimited
       .TextFileTextQualifier = xlTextQualifierDoubleQuote
       .TextFileConsecutiveDelimiter = False
       .TextFileTabDelimiter = True
       .TextFileSemicolonDelimiter = False
       .TextFileCommaDelimiter = False
       .TextFileSpaceDelimiter = False
       .TextFileColumnDataTypes = Array(2)
       .Refresh BackgroundQuery:=False
   End With
End Sub
When I click it, it imports information from a textfile as you see.
Allthough the information is printed out on sheet where the button is.
I bet it has something to do with "With ActiveSheet" statement.
I want the data from the textfile to be prionted in sheet .
How?
And my second question is how can this macro import data from all *.txt files under a certain path.
In this case it's only one file.
Is it like:
"TEXT;H:\MyPath\*.txt", _
.Name = "*.txt"
Thanx
Forgive me if I'm wrong but that looks morelike an Excel macro than an AutoCAD macro ?
