M Phillips Posted January 13, 2010 Share Posted January 13, 2010 I have a dynamic block with an array action which doesn't act as I want it to. I've browsed the site for similar problems but as yet haven't been able to find a fix that I can apply to my block. On the attached drawing, I have a grips to stretch the block vertically and horizontally. The vertical stretch is fine, it's the horizontal where I'm having problems. As the block is stretched the sets of 3 vertical lines should appear at either end and at intervals of 1500mm with a section on the right of either exactly 1500mm or less. At present this right hand section always between 1500mm & 3000mm. Any ideas? Drawing1.dwg Quote Link to comment Share on other sites More sharing options...
