Sudhir Posted August 13, 2008 Posted August 13, 2008 HI guys can any body help me to write a lisp program for publish Quote
borgunit Posted August 13, 2008 Posted August 13, 2008 You are being way too vague. What do you want to do exactly? Quote
Sudhir Posted August 14, 2008 Author Posted August 14, 2008 You are being way too vague. What do you want to do exactly? I want a lisp program for printing all layouts at once by using publish command Quote
CmdrDuh Posted August 14, 2008 Posted August 14, 2008 why not just use the publish command then Quote
JeepMaster Posted August 14, 2008 Posted August 14, 2008 If you want a script to do all the printing for you. Then you could write a lisp and use the -plot command. Just write down all the steps into a lisp file and run it in ScriptPro or similar program to plot all your dwgs. ie: -plot Y A0 \\YOUR PRINTER ISO A0 (841.00 x 1189.00 MM) M L N E ... Quote
Sudhir Posted August 14, 2008 Author Posted August 14, 2008 Its ok But we have drawings with number of layouts means average 20 layouts in single drawing so i want to give print all layout at once by using the lisp program thats why i want a publish lisp Quote
JeepMaster Posted August 15, 2008 Posted August 15, 2008 I've seen a lisp like that somewhere posted. Did you do a search? Quote
JeepMaster Posted August 15, 2008 Posted August 15, 2008 How about running this script to all your dwgs using scriptpro(or whatever). It seems to work fine. (foreach tn (layoutlist)(command "-plot" "N" tn "" "PDF.pc3" "" "N" "Y")) Adjust the plot command options that suits you. Quote
CAB Posted August 15, 2008 Posted August 15, 2008 This may be of some use, but I thought Publish would handle what you wanted. ;;; -=< D E S C R I P T I O N >=- ;;; Routine to plot paperspace tabs ;;; Pick Page Set Up to use ;;; Sort Tabs by Alpha, Numeric, or Tab order; controls the pick list order too ;;; Reverse sort order of Tabs ;;; Pick tabs to plot via list, use SHIFT CLICK to pick a range or use ;;; CTRL CLICK to tag individual names, 'Plot All' must be unchecked ;;; This list order is determined by the Sort Tabs Radio Buttons ;;; Ignore Tabs with flag character, this works with Pick Tabs too ;;; Enter quantity of copies ;;; Option to collate ;;; ;;; Enter PlotTabs to run from the command line ;;; You may call sub_PlotTabs wit a list of options see notes below Member Required Link Quote
