annemarie246 Posted January 13, 2010 Posted January 13, 2010 Using AutoCAD 2004 Solid hatch will not print. Areas I have filled won't print and solid arrows print as open arrows. Really need the hatched areas to be solid. Any help is appreciated. Quote
hugha Posted January 13, 2010 Posted January 13, 2010 Looks like fill is currently off. Try turning it on by: Command: FILL Enter mode [ON/OFF] : ON or Command: FILLMODE Enter new value for FILLMODE : 1 Hugh Adamson www.hatchkit.com.au Quote
annemarie246 Posted January 14, 2010 Author Posted January 14, 2010 Both those items are set correctly, Fill - on and Fillmode at 1. One thing I just noticed is the filled items that I have in Paper space will print, but the items in the viewport will not. And the layers they are on are not turned off. Quote
hugha Posted January 14, 2010 Posted January 14, 2010 More settings to try: http://www.cadforum.cz/cadforum_en/my-autocad-does-not-display-solid-hatches-and-fills-tip6942 If PDF is involved try another PDF driver. Try printing from another computer / ACAD version / Trueview http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112 Quote
