Anyone have a routine that has the ability to globally redefine the width of plines within blocks? Like a colorbylayer lisp I already use.
I was given a background file the the walls and columns are made up of plines that have widths. So there is a separate block defined for each column, wall section, window...
This will change it within the Block Definition in the drawing:
(defun c:test (/ *error* PolyChng str wid uFlag)
 (vl-load-com)
 ;; Lee Mac  ~  15.01.10
 (defun *error* (msg)
   (and uFlag (vla-EndUndoMark doc))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (defun PolyChng (blk wid)
   (vlax-for obj (vla-item (vla-get-Blocks doc) blk)
     (if (eq "AcDbPolyline" (vla-get-Objectname obj))
       (vla-put-ConstantWidth obj wid))))
 (setq doc (cond (doc) ((vla-get-ActiveDocument
                          (vlax-get-acad-object)))))
 (while
     (setq str (getstring t "\nSpecify Block Name: "))
     (cond (  (not (snvalid str))
              (princ "\n** Invalid Block Name **"))
           (  (tblsearch "BLOCK" str)
              (initget 4)
              (setq wid (cond ((getdist "\nSpecify New Width <0.0> : ")) (0.0)))
              (setq uFlag (not (vla-StartUndoMark doc)))
              (PolyChng str wid)
              (setq uFlag (vla-EndUndoMark doc)))
           (  (princ "\n** Block Not Found **")))))
 (vla-regen doc acActiveViewport)
 (princ))
Anyway to get that to be global? If I start with the column blocks that would be 53 different defined blocks to do.
Maybe I should just explode all blocks in the drawing...
Sure, try this:
(defun c:test (/ *error*  wid uFlag)
 (vl-load-com)
   (princ))
 (initget 4)
 (vlax-for blk (vla-get-Blocks doc)
   (vlax-for obj blk
 (princ))
That is great, done in a blink.
Thanks so much!
