kspatter Posted January 16, 2010 Posted January 16, 2010 In AutoCAD there is a command called SOLPROF (SOLID PROFILE). This command allows the user to take a 2D shot of a 3D solid. However AutoCAD later developed a better routine that did the same thing. I can't remember the command line for that. Does anyone know what i am speaking of? Quote
SuperCAD Posted January 16, 2010 Posted January 16, 2010 Flatshot is a lot easier to use, however all of the lines are set to a 0.00mm lineweight so you'll have to adjust it to get it to look good. With SECTIONPLANE, you have more control over your lineweights and hatch patterns but you can't do isometric views. Quote
