I cant get why I am not able to create a single pdf file containning all the layouts of my drawing. When i do so, it creates single pdf file for each page so I end up with multiple pdf files instead of only one with all the pages on it.
Can you help?
You have answered your own question single pdf's produced, I use adobe acrobat to rejoin them all into one document.
Search here this has been discussed before.
What is PUBLISHCOLLATE variable set to? See help.
If you use Batch Plot, then you get one PDF-file with several pages.
Take it back but more confused you can "publish" 2009 multiple layouts to one pdf.
Butttttttt it has a mind of its own sometimes it works other times you get only one thats why I stopped using it we needed to publish around 150 drawings as a set and it did all sorts of screwy things would work partially leave drawings out it became more frustarting and as the drawings were a master set had to be right.
