Dear all of CADtutor Friend
I just new member, and need help from someone
Who have some autolisp or technic how to Convert AutoCAD (Text) to Excel, help me please
have you had a look through some of our old threads? I'm fairly certain we've been asked this before
it isn't a good idea to post your email address on the internet btw - it can be harvested and used for all kinds of things you don't want to receive!
Thank you very much Strix, Let me find that old question
A simpler way would be to output from AutoCAD in a so called CSV file. It can be opened in Excel too.
Dear Fuccaro
I found some Autolisp code below, But only 1 problem
this code read and sort from bottom to top
How I modify this code read Text from Autocad Then show to Excel
from top to Bottom
Thank and Regard Sir.
(defun c:ttx ( / xlCells xlSheet xlSheets xlBook xlBooks xlApp column row drac ss ent expo x)
(vl-load-com)
(setq xlApp (vlax-get-or-create-object "Excel.Application")
xlBooks (vlax-get-property xlApp "Workbooks")
xlBook (vlax-invoke-method xlBooks "Add")
xlSheets (vlax-get-property xlBook "Sheets")
xlSheet (vlax-get-property xlSheets "Item" 1)
xlCells (vlax-get-property xlSheet "Cells"))
(vla-put-visible xlApp :vlax-true)
(setq column 1
row 1
drac -1
ss (ssget "_X" (list (cons 0 "*TEXT"))))
(repeat (sslength ss)
(setq ent (ssname ss (setq drac (1+ drac)))
expo (vla-get-textstring (vlax-ename->vla-object ent)))
(if (
(vlax-put-property xlCells "Item" row column expo)
(setq row 1
column (1+ column))
); /else progn
); /if
(setq row (1+ row))
); /repeat
(mapcar (function (lambda(x)
(vl-catch-all-apply
(function (lambda()
(vlax-release-object x)
(setq x nil)))))))
(list xlCells xlSheet xlSheets xlBook xlBooks xlApp))
(alert "Close Excel file manually")
(gc)(gc)
)magic
You can use DATAEXTRACTION too , it will do all hard work.
No code needed
  • 1 year later...
Can you please tell me how this DATAEXTRACTION work?
Just follow de Dialog box instructions , and use the help
Type DATAEXTRACTION at the command line .
thank you, but it does not copy all the details to excel file and also the order is not what it should be.
what i need is to copy all the data in an autocad file and create a table in excel but dataextraction arranges all the values in single column which is not what is required. (formatting etc can be taken care of later).
please help
Can I get these details in coma separated format?
