Hi!
I am using autocad civil 3d 2008.
I am writing a lisp and want to use pline command in it, and use 'so - tranparent commands. But cannot select them. Writing by hand i can select them.
Any ideas whay?
the error
_.pline
Specify start point: '_so
Invalid point.
; error: Function cancelled
Thanks it works!
Can somebody explain how i can run _.so get the aligment i need and put all the data in.
(command "_.so" "something here to ask for aligment" and "data")
How does data must look like
I have this code now
(defun c:papl ()
(vl-load-com)
(setq al (ssget)) ;;select aligment,but i dont realy want this here because it ;;;is possible to select another object not aligment,
(command "_.so" al "10" "5" "20" "10") ;;;inputing data this way i get an erro
Command: papl
Select objects: 1 found
Select objects: _.so
Select alignment:
Specify station: 10
Specify station offset: 5
Command: 20 Unknown command "20". Press F1 for help.
Command: 10 Unknown command "10". Press F1 for help.
Hey, I decided to change the concept of my lisp. Now I know how i can get without intersection points. I will use aligment and tranparent commands.
I want to bulid a road with the additional slowing line. I allways have an aligment so i want to use it, the concept is i do not need to do the geometry intersection points finding, just simple maths. I use pline=>'so command to find the point coordinate, My code now looks like that.
(defun c:papl ()
(vl-load-com)
(setq al (ssget))
(command "_.so" al "10" "0")
in console it gives me
Command: PAPL
Select alignment:
Specify station: 10
Specify station offset: 0
Command:
Command: (21.9795 19.8182 0.0) ;;;i need to get that point and use it in building polyline
Can somebody help me with getting the point, thanks!
