I want to create my own hatch in acad09. I cannot find the area where you do this. I cant find it in my acad09 bible either. Can someone tell me where in acad you do this and any hints that I might render to need.
tnx
wow i found it in my acad09 bible. it looks very complicated. you have to creat pat files and what not. you would think it could be a little easier.
Check what you are doing carefully against the points bulletted in this link:
http://usa.autodesk.com/adsk/servlet...linkID=9240617
These links show how to repetitively intersect individual hatch pattern lines to to create a pattern with the aid of a text editor.
http://www.ccadinc.com/tips/creating...hpatterns.html
http://www.upfrontezine.com/tailor/tailor12.htm
http://www.caddigest.com/subjects/au...h_patterns.htm
http://www.caddigest.com/subjects/au..._patterns2.htm
Graphical hatch pattern editors or generators speed production of more complex patterns.
Also search the web for "hatch pattern" - there's a wide choice.
Hugh Adamson
www.hatchkit.com.au
Maybe you were thinking of the SuperHatch command found in Express Tools.
