h0wi3 Posted August 14, 2008 Posted August 14, 2008 Hi, I'm used to Solidworks and now I'm using AutoCAD. I can't seem to figure out how to assemble the parts i created together. In Solidworks I would just specify the constraints. Do I have to move it manually in AutoCAD ? or is there a function or a software that will let me do the assembly more easily ? Thanks in advance Quote
ReMark Posted August 14, 2008 Posted August 14, 2008 You must be talking about a 3D drawing, right? Have you tried the Align command? Quote
h0wi3 Posted August 21, 2008 Author Posted August 21, 2008 Hmm. tried that. How do you mate a shaft to a hole ? I can't seem to use the 3D align for this.. help.. Thanks in advance Quote
nocturne00 Posted August 21, 2008 Posted August 21, 2008 You'll need to get very well aquinted with the UCS of autoCAD first, rotation of the crosshairs, and where to actually snap your objects in place. but from I can tell, youll need to locate the center of the hole and center of the shaft, align and snap those together by the way, youll need to activate "center" in your ONSNAP settings Quote
Noahma Posted August 21, 2008 Posted August 21, 2008 You'll need to get very well aquinted with the UCS of autoCAD first, rotation of the crosshairs, and where to actually snap your objects in place. but from I can tell, youll need to locate the center of the hole and center of the shaft, align and snap those together by the way, youll need to activate "center" in your ONSNAP settings you can type in CEN as well which will constrain your snap to the center point. after clicking once it will revert back to the osnap settings you have active. Quote
