I am having a unique issue I have not been able to find anywhere else. I am currently running Autocad 2009 with Carlson Civil 2009 on top of it. Everything has been fine for several months. However, all of a sudden I cannot access my Autocad options dialog box. All other dialog boxes come up fine, including the open dialog...but whenever I type options, of select options from the settings menu, nothing happens. My cursor changes to the standard mouse pointer then sits there until i hit escape. No errors or other messages. I can still change variables if I know what they are. I have also tried a repair install to no avail...any ideas? :? Thanks in advance...
Off screen maybe? Try options again, then hit Alt+Space. then M (for Move), then use the arrow keys to move it back on screen (or S for size, arrow keys to resize till you can see it).
You are a genius. Thank you. I thought about that, but had no idea how it could have happened. I did not know what the shortcuts were to accomplish that...once again, thank you and problem solved :D
