Inserting lots of DWG files into CAD
Hello All,
Im sure this must have been mentioned before but I cannot find it.
I have about 120 files I wish to insert into a AutoCAD 2010 drawings, but want to know if there is a quicker way, rather than inserting each individual tile.
Thanks,
Mark
Jeez, I hope these aren't big files. What kind of drawing is this? When you say 120 files are you referring to blocks?
I suppose you could write a script file to handle the task. Hope your system doesn't crash in the middle of the operation.
Yes, its 120 blocks, namley OS Tiles. There about 0.25mb for each file.
I was afraid you would say I needed to do a script file!
Forgive my ignorance. What are OS Tiles? Why do they have to be inserted individually?
Afraid of using a script file?
Its an ordance survey map tile, its just a block.
AutoCAD will not let me insert more than 1 block at a time, unless there is a way?
Just a thought - I've not tried this but, if you open Windows Explorer and multi select your drawings can they be drag/dropped into your AutoCAD drawing windo?
nope...only a single file can be dropped as an inserted item...
Simple reason for this - every block needs to have an insertion point provided. This would mean that the software would need to switch backwards and forwards between Explorer and AutoCAD.
Maybe DesignCentre may be a good option for getting them in? Albeit individually, at least you remain in and AutoCAD interface where you can click and drag???
