Hi Guys & Girls
Have a few selection problems. (Sorry I'm an Autocad LT user)
1 - Need to draw a line in a macro and then later select the start & endpoint of the same line. $(getvar,lastpoint) works for the last point but cannot select the first point. Any ideas?
2 - Need to select;last; when using the measure command but does not work. Any ideas? Is there a deisel command that will do this for me?
3 - Want to create drop down menu that swaps contents depending on top level menu serection. What code do I use? See below example.
My Meny
'Menu A'
Menu B
Menu C
a-1
a-2
a-3
a-4
I know how to do flyout secondary menu's but not swap menu's. Any Ideas?
