hi,
i am currently woring on a mechanical project an assembly of huge animated sequences. it has huge number of faces amounting more than 20000 numbers.. the model is a NURB surface. i am finding it difficult to render. for it stops and does not render the model. please help & suggest thank u
What are your computer specs?
What rendering engine are you using? Mental Ray? Vray? Scanline? Other?
What are your render settings? Are you usinig Global Illumination and/or Final Gather?
What type of materials are you using? Do you have a lot of shiny, reflective materials like chrome? Or are you using a lot of bump or displacement maps?
What type of lighting are you using? Are you using a daylight system?
Are you sure it's stopping? Sometimes it will appear that the render has stopped, but in reality, it's just computing a very difficult area of the image and may stall for a very long time before moving on.
Comp spec would be interesting to know sounds like a big project.Again have to agree too little detail to give any assistance Can you post what Renderer you are using?? how long has it stopped for??? not un-common to really slow down at certain points.
