georgi913 Posted February 1, 2010 Posted February 1, 2010 Hello guys, I'd like to ask you, if there is a lisp routine, where you can create lines between two polylines, that have the same number of points - every of which point/vertex is perpendicular with the one below or on top of it. It would be awesome because i have so many cross sections, where i have to do this, between every point that your head will hurt Thank you guys in advance! here's an example of what i need: example_.dwg Quote
Lee Mac Posted February 1, 2010 Posted February 1, 2010 Perhaps: (defun c:VLines (/ line ent1 ent2 i p1 p2) (vl-load-com) ;; Lee Mac ~ 01.02.10 (defun line (p1 p2) (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2)))) (while (progn (setq ent1 (car (entsel "\nSelect First Polyline: "))) (cond ( (eq 'ENAME (type ent1)) (if (wcmatch (cdr (assoc 0 (entget ent1))) "*POLYLINE") (while (progn (setq ent2 (car (entsel "\nSelect Second Polyline: "))) (cond ( (eq 'ENAME (type ent2)) (if (wcmatch (cdr (assoc 0 (entget ent2))) "*POLYLINE") (progn (setq i (1- (vlax-curve-getStartParam ent1))) (while (and (<= (progn (setq p1 (vlax-curve-getPointatParam ent1 (setq i (1+ i)))) i) (vlax-curve-getEndParam ent1)) (setq p2 (vlax-curve-getPointatParam ent2 i))) (line p1 p2))) (princ "\n** Invalid Object **")))))) (princ "\n** Invalid Object **")))))) (princ)) Quote
georgi913 Posted February 1, 2010 Author Posted February 1, 2010 Thank you! It worked like a charm, you saved my ass Quote
Lee Mac Posted February 1, 2010 Posted February 1, 2010 Thank you! It worked like a charm, you saved my ass You're welcome Quote
