Dana W Posted April 30, 2015 Posted April 30, 2015 What about the four year old solution stated above? Did you try that one? Whst was the result? Quote
a3amanda Posted May 1, 2015 Posted May 1, 2015 I have tried all the possible solutions from the old thread with no luck. I've also done the obvious check of pickfirst, pickadd and pickauto-all set to 1. The main issue is with fencing. I can directly select an object (with a slight 1-2 second freeze) but I cannot window or fence to select anything. Please please please someone help me. Quote
Dana W Posted May 1, 2015 Posted May 1, 2015 I just noticed your profile says you are using Architecture 2015. I don't know anything about how that works, so I'll step back and let someone else take a stab. It would help if we knew your system stats including video card, and something about the drawing. Maybe post a copy of the drawing here, minus titles and proprietary stuff. Are you pulling in any xrefs? Is it 3D? Quote
Dadgad Posted May 1, 2015 Posted May 1, 2015 Welcome to CADTutor, What visual style do you typically work in? Try it in 2D Wireframe, if that is not your usual visualstyle, that may help. Quote
Cad64 Posted May 1, 2015 Posted May 1, 2015 What sort of objects are you selecting? I have seen hatches cause problems sometimes. Quote
a3amanda Posted May 1, 2015 Posted May 1, 2015 Selecting anything. It can be as simple as a line. It's mostly when windowing or fencing the objects. Even just one object. Quote
Cad64 Posted May 1, 2015 Posted May 1, 2015 Well, as Dana mentioned, I guess we need to know a little bit about your computer. Processor, RAM, Video Card, Operating system, etc. Also, do you have hardware acceleration enabled? http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-enable-or-disable-hardware-acceleration-in-AutoCAD.html Quote
Dadgad Posted May 1, 2015 Posted May 1, 2015 (edited) Selecting anything. It can be as simple as a line. It's mostly when windowing or fencing the objects. Even just one object. What visual style do you typically use? Sounds like a graphics issue possibly, if so 2D Wireframe might help. Adaptive Degradation might provide some relief too. Edited May 1, 2015 by Dadgad Quote
Dana W Posted May 2, 2015 Posted May 2, 2015 Ahem. (taps foot.) Answer a few of the questions we've posted, and it will go a lot faster, we have pretty much nothing to go an and there are literally hundreds of reasons this could happen. Quote
Cad64 Posted May 5, 2015 Posted May 5, 2015 Well, I guess the OP figured out what was wrong, or learned to live with the freezing? Quote
Acadresponder Posted July 6, 2019 Posted July 6, 2019 I had a similar problem. I had created a chart with asignificant amount of multiline text. I then converted the chart/text to a block so that I could rotate and move it. After a period of time I started having this issue. I tried everything, purge, audit, copy into new drawing. Nothing worked. Finally I exploded the block and that resolved the problem. I don't know why. Quote
