I'm stumped.
The following code returns filenames, but only returns nil for the modification date of each file.
This code is just the building block for a simple program that will purge .bak files from a specified folder after they've been in there for some given period of time.
Any ideas why I'm only getting nils returned to me?
(defun Sbu(/ thefile thelist datemodified)
 (vl-load-com)
 (setq thelist (vl-directory-files "c:\\test\\" "*.*" 1))
 (foreach thefile thelist
   (setq datemodified (vl-file-systime thefile))
   (print thefile)
   (print datemodified)
 );foreach
);defun
Thanks,
Joe
(defun Sbu (/ thefile thelist datemodified)
(vl-load-com)
(setq directory "c:\\test\\")
(setq thelist (vl-directory-files directory "*.*" 1))
(setq datemodified (vl-file-systime (strcat directory thefile)))
(print thefile)
) ;_ end_foreach
) ;_ end_defun
Oh, I see my error now. I was referencing the filename, but had omitted the path.
Thanks wizman!
