NH3man! Posted February 7, 2010 Posted February 7, 2010 I was wondering if there is a way to clear out all text heights so that there is only one. Right now mine had 4.5, 3, and some fractional ones. I only use the 3 most of the time but I keep having to select it now because it defaults to the largest height. Thanks Hope you can help. NH3man! Quote
feargt Posted February 7, 2010 Posted February 7, 2010 You could create a text style with a fixed height of 3 , and make this style current. Quote
NH3man! Posted February 7, 2010 Author Posted February 7, 2010 Thanks, I did that but still would like to know if they can be cleared. Thanks again NH3man! Quote
Tankman Posted February 7, 2010 Posted February 7, 2010 You would have to have the style saved, the empty file (template), that you use. Before then, you would have to modify properties and change text heights. I don't know if you can do this globally. Each time I start a new file with my template I get the same results. Dimensions, text height, colors, whatever. Quote
