Robert Sheffield Posted August 15, 2008 Share Posted August 15, 2008 Autocad Version: 2009 This is a macro I wrote for Autocad and it works fine in versions through Autocad 2008. When I try to use it the macro stops when it gets to: -INSERT;TAG-ATT;@;;;;. TAG-ATT is a block attribute drawing. Could someone please help and tell me why this macro will not insert the TAG-ATT block into the drawing in Autocad 2009? All drawings are in the search path *^C^C-LAYER;M;FS-ITEM;C;W;;;-INSERT;DONUT;\;;;LINE;@;\;-INSERT;*ELLIPSE;@;;;SELECT;L;;ID ENDP,QUI @ TRIM P ;ENDP,QUI @;;-INSERT;TAG-ATT;@;;;; Quote Link to comment Share on other sites More sharing options...
Strix Posted August 17, 2008 Share Posted August 17, 2008 is it the path for the file that's the problem? is 2009 looking in a directory of it's own whilst the file is in a previous edition? Quote Link to comment Share on other sites More sharing options...
Robert Sheffield Posted August 17, 2008 Author Share Posted August 17, 2008 That is not the problem. I wish that was all it was Quote Link to comment Share on other sites More sharing options...
hendie Posted August 17, 2008 Share Posted August 17, 2008 have you checked that the prompt sequence hasn't changed between versions ? Quote Link to comment Share on other sites More sharing options...
CarlB Posted August 17, 2008 Share Posted August 17, 2008 Are applicable system variables set the same as previously- ATTDIA and ATTREQ? Quote Link to comment Share on other sites More sharing options...
Robert Sheffield Posted August 18, 2008 Author Share Posted August 18, 2008 Attdia Set To 0 Attreq Set To 1 Quote Link to comment Share on other sites More sharing options...
