rodyyy Posted February 10, 2010 Posted February 10, 2010 hi guys I need to incorporate a 5.0 metre radius bend into autocad 09 any help would be good Quote
paulmcz Posted February 10, 2010 Posted February 10, 2010 where would you like to have the center point of your arc? Quote
rodyyy Posted February 10, 2010 Author Posted February 10, 2010 thanks guys i have tried the ARC help and got a radius to large message i need the centre of the arc to be in the middle Quote
paulmcz Posted February 10, 2010 Posted February 10, 2010 i need the centre of the arc to be in the middle OK, that's clear. Now, where would you like to have a start point of your arc? Quote
PS_Port Posted February 10, 2010 Posted February 10, 2010 I'm guessing you probably want the start point of the arc to be at the beginning... and and the finishing point at the end. roddy, since you used the word 'incorporate' I'm assuming you already have some sort of linework? If so, try the FILLET command then `R' to set a radius. If this is not your situation then I think we are going to need a little bit more info. Paul. Quote
Tankman Posted February 10, 2010 Posted February 10, 2010 I'm guessing you probably want the start point of the arc to be at the beginning... and and the finishing point at the end... Thanks Paul! Can we start the arc at the end, working backwards, finish up at the beginning? A little more information would be invaluable, I think? Radius too large, you've run out of room rodyyy. Do you need a full 90° arc? Just a little arc, 5 meter, a small piece? 5° maybe? Welcome to the forums! Visit often and, by the way, where are you posting from? Quote
