ReMark Posted February 10, 2010 Posted February 10, 2010 It won't work the way you have it because defun E: should really be defun C: Bill. Please change it. From Jeffery P. Sanders - The AutoLISP Beginner: "The C: tells AutoCAD that you want this program to be executed at the Command Prompt like a built in function." Quote
BILL WILLIAMS Posted February 10, 2010 Author Posted February 10, 2010 My S::STARTUP (defun S::STARTUP () (defun C:ahl()(command "ahl")) (defun C:arcl()(command "arcl")) (defun C:cb()(command "cb")) (defun C:cl()(command "cl")) (defun C:ctst()(command "ctst")) (defun C:dct()(command "dct")) (defun C:ddt()(command "ddt")) (defun C:ds2()(command "dst")) (defun C:dwgscale()(command "dwgscale")) (defun C:ddts()(command "ddts")) (defun C:ddtext()(command "ddtext")) (defun C:edd()(command "edd")) (defun C:erasenodes()(command "erasenodes")) (defun C:dct()(command "dct")) (defun C:exblock()(command "exblock")) (defun C:exchprop()(command "exchprop")) (defun C:cb()(command "cb")) (defun C:cl()(command "cl")) (defun C:fr()(command "fr")) (defun C:io()(command "io")) (defun C:is()(command "is")) (defun C:iso()(command "iso")) (defun C:isodim()(command "isodim")) (defun C:isoviews()(command "isoviews")) (defun C:killdots()(command "killdots")) (defun C:lad()(command "lad")) (defun C:lcr()(command "lcr")) (defun C:lts()(command "lts")) (defun C:match()(command "match")) (defun C:met()(command "met")) (defun C:mirrors()(command "mirrors")) (defun C:mva()(command "mva")) (defun C:pkill()(command "pkill")) (defun C:pic()(command "pic")) (defun C:pickstyl()(command "pickstyl")) (defun C:pl2cloud()(command "pl2cloud")) (defun C:pua()(command "pua")) (defun C:qw()(command "qw")) (defun C:qww()(command "qww")) (defun C:respace()(command "respace")) (defun C:reverse()(command "reverse")) (defun C:rda()(command "rda")) (defun C:rot2ent()(command "rot2ent")) (defun C:sa()(command "sa")) (defun C:scl()(command "scl")) (defun C:sp2sp()(command "sp2sp")) (defun C:steel()(command "steel")) (defun C:stl()(command "stl")) (defun C:stc()(command "stc")) (defun C:sx()(command "sx")) (defun C:taa()(command "taa")) (defun C:tc()(command "tc")) (defun C:tedit()(command "tedit")) (defun C:tmm()(command "tmm")) (defun C:txtchg()(command "txtchg")) (defun C:utext()(command "utext")) (defun C:aweld()(command "aweld")) (defun C:wbl()(command "wbl")) (defun C:widedit()(command "widedit")) (defun C:wftext()(command "wftext")) Quote
ReMark Posted February 10, 2010 Posted February 10, 2010 If you read the article referenced in the first link I posted you'll notice that there are 21 listed items that AutoCAD loads in sequence. S:STARTUP is dead last. 20 other items are loaded ahead of it. Quote
BILL WILLIAMS Posted February 10, 2010 Author Posted February 10, 2010 I read the article but I don't recall there being 20 items loaded first. FIRST: Is my startup correct? SECOND: Is there a problem with it loading last and if so how can I get it to load close to the beginning? Quote
ReMark Posted February 10, 2010 Posted February 10, 2010 The "list" in the link I provided comes courtesy of Steve Johnson the author of blog nauseam. In summary, here is the AutoCAD startup sequence: A. CUI files loaded: 1. Enterprise 2. Main 3. Partials to Main 4. Partials to Enterprise B. acad*.* files loaded: 1. Files listed in acad.rx 2. acad2009.lsp 3. acad.lsp 4. acad2009doc.lsp 5. acaddoc.lsp 6. acad.dvb C. CUI-associated MNL and LSP files loaded: 1. Enterprise named MNL 2. Enterprise loaded LSP and MNL 3. Main named MNL 4. Main loaded LSP and MNL 5. Partials to Main named MNLs 6. Partials to Main loaded LSPs and MNLs 7. Partials to Enterprise named MNLs 8. Partials to Enterprise loaded LSPs and MNLs D. Startup suite files loaded E. Startup routines run: 1. AcadStartup() called (AutoCAD startup) 2. AcadDocument_Activate() called (Drawing startup) 3. (S::STARTUP) called There it is ^ ^ ^ ...DEAD LAST! Quote
BILL WILLIAMS Posted February 10, 2010 Author Posted February 10, 2010 Again, please, is my startup correct? Is there a problem with it loading last and if so how can I get it to load close to the beginning? Quote
ReMark Posted February 10, 2010 Posted February 10, 2010 Yes, I believe your STARTUP is correct. I'm glad to see you have defun C: and not defun E: as you had indicated earlier. I know there are other ways to load Lisp routines earlier in the startup process some methods of doing so have been discussed here several times in the past. RKMcSwain and Lee Mac have contributed their expertise on the subject and I would trust what they have to say about the "best" way to do it. Quote
BILL WILLIAMS Posted February 10, 2010 Author Posted February 10, 2010 I don't care if the loadup is last as long as I can get my lisp to work when I call on them. There is only one loadup, right? When I first open AutoCAD for the day's business. Quote
ReMark Posted February 10, 2010 Posted February 10, 2010 Yes...one load up as you put it. BUT...there can be more than one S:STARTUP as the article I keep referencing mentions. If something gets screwed up some or all of your lisp routines may not be available to you. Quote
BILL WILLIAMS Posted February 10, 2010 Author Posted February 10, 2010 As far as I know I have the only start up. Thanks for putting up with me. I have learned much today. Quote
ReMark Posted February 10, 2010 Posted February 10, 2010 You're welcomed. I hope that things work out the way you want (and expect) them to. Quote
