viriato79 Posted February 10, 2010 Posted February 10, 2010 I need to label for each alignment station the elevation of that point? How can I do that? Thanks Quote
BIGAL Posted February 11, 2010 Posted February 11, 2010 I think you can create your own station label style by starting with an existing one and changing the label's text ouput. hope this is right go to Toolspace settings alignments major station copy then double click it then the properties box should come up pick layout then look at the TEXT options particuarly content you should be able to add Z and remove other values CH haven't had to do this but noticed one style has DZY as option so try Z only Quote
