Hi
I want to print the layouts in the drawing all at one time. Just doing Print once.
How can I do that?
Thank you very much.
Select all the laouts using Ctrl... rt-click and select Publish Selected Layouts
Ok thanks! But How can I change the printer from the page setup?
Try saving another page setup with different printer info. I use several different page setups one for each printer, ctb file, etc.
Set up all your plot page set ups a simple trick is PLOT do all your settings give it a name and save, then "save to layout" then "cancel" the plot setttings are saved even though you have done a cancel.
Ours are set up in our template you can also IMPORT pre set or custom ones from other drawings which is handy, Just got to remember which drawing.
