refedit and text issues
Ok, so I'm using autocad2008, and working on a project that has numerous xrefs. I double click to edit on, save and return to my drawings, and now i cannot edit or even select several text's on one particular layer. Some of them i am able to, but others cad treats like they are not even there. Some help would be most gratefully appreciated.
mn
also it may be some sort of a variable setting. a coworker can select and modify the text, but i cannot.
also, if i go to the layout page I can modify the text there. Then if i go back to model, i can select the text. So i have a work around, but am still curious as to why this is happening
