Hi all, I am currently working on a drawing that has got a few raster images in the background. When I try to plot the plan to pdf on my 32bit Vista PC some of the images does not show on the plot. I have set my rasterthreshold on the max of 2000 and it then plotted more but still not all.The same plan when plotted on a 64bit Vista PC is fine, all images show.
My questions are:
Is there a way to increase the rasterthreshold above 2000?
Is the problem I am having because of 32bit operating system?
The printer I use for pdf is the 1 that comes with Acad 2010, dwg to pdf, should autodesk not have made sure that the driver would be able to cope?
PS: why would the same printer work then on 64 but not on 32?
You're talking about two different machines. What are the system specs of the 64 bit machine vs. the 32 bit machine?
The 64bit is Core2Due laptop with 4Gb RAM, 32bit is Cuadcore desktop with 4Gb RAM.
Not sure about the specifics.
