Dashed column grid shows solid in layout
Good day!
I am using Autocad Architecture 2008. I made coulmn grid in model space with annotation scale 1:100 and grid lines look dashed, like they suppose to. When I switch to layout space, those lines look solid. There is something wrong with the scaling and I can't find where to adjust it. Can somebody help me with this issue?
Thank you!
Check what values your LTSCALE and PSLTSCALE are set to
ltscale is 0.5, psltscale is 0 ....what shall I do next?:)
change ltscale to something higher (or lower), keep changing it until the dashes look good.
or you could change PSLTSCALE to 1
