Lee Mac Posted February 13, 2010 Posted February 13, 2010 Why is the search utility limited to searching words of length > 3? Quote
nukecad Posted February 13, 2010 Posted February 13, 2010 Most forums are, Vbulletin that drives this forum definetely is. Less than four characters in a search string would be ambiguous and give too many matches. And yes we know that it can be awkward if you want to search for a 3 character file extension. Quote
David Bethel Posted February 13, 2010 Posted February 13, 2010 I run into a lot. Just search for '3D' anything. -David Quote
Lee Mac Posted February 13, 2010 Author Posted February 13, 2010 I only bring up the point as I don't have this trouble on theSwamp - not trying to pitch the two against each other, but just wondered if it was an admin imposed restriction. Quote
CADTutor Posted February 16, 2010 Posted February 16, 2010 It's to do with the way search is handled by the database. Or more correctly the way it was designed. In order to enable 3 character strings, the database would grow exponentially and search would take much longer. The workaround is to use the wildcard character as in *dwg*. I understand that search is much improved in vB4. We'll see... Quote
Lee Mac Posted February 16, 2010 Author Posted February 16, 2010 It's to do with the way search is handled by the database. Or more correctly the way it was designed. In order to enable 3 character strings, the database would grow exponentially and search would take much longer. The workaround is to use the wildcard character as in *dwg*. I understand that search is much improved in vB4. We'll see... I understand, thanks David Are we going to be upgrading to vB4 then? Quote
