I want to update this lisp
;to select all dimensions
(defun c:dms(/ dimsel)
(setq dimsel(ssget "x" '((0 . "DIMENSION"))))
(command "_PSELECT" "_p" "")
(PRINC)
What I want is to add another condition "when layer is ON" because this lisp select all dimension even in OOF layers.
I got the reason (when value of DXF code 62 is negative) but couldn't add the condition.
Could _SELECT be used in state of _PSELECT?
Because PSELECT command needs properties palate opened at least one time.
How about;
(defun c:dms nil
 (sssetfirst nil (ssget "_X" '((0 . "DIMENSION"))))
 (princ))
Still select dimensions in OFF layers
Hows this?
(defun c:dms (/ ss)
 (if (setq ss (ssget "_X" '((0 . "DIMENSION"))))
   (sssetfirst nil
     (last
       (mapcar
         (function
           (lambda (x)
             (if (minusp
                   (cdr
                     (assoc 62
                       (entget
                         (tblobjname "LAYER"
                           (cdr
                             (assoc 8
                               (entget x)
               (ssdel x ss) ss
         (mapcar
           (function cadr)
             (ssnamex ss)
At the risk of being shown up by Lee or someone else... Here is one way to do it...
(defun c:dms(/ dimsel ent lst lay col newss i)
(setq dimsel(ssget "x" '((0 . "DIMENSION"))) i 0 newss (ssadd))
(repeat (sslength dimsel)
 (setq ent (ssname dimsel i))
 (setq lst (entget ent))
 (setq lay (cdr (assoc 8 lst)))
 (setq lyr (entget (tblobjname "layer" lay)))
 (setq col (cdr (assoc 62 lyr)))
 (if (not (minusp col))
   (ssadd ent newss)
 (setq i (1+ i))
(command "_PSELECT" newss "")
(PRINC)
If you had thousands and thousands of entities and layers, you would probably want to add some more code that you can avoid checking the same layer twice.
At the risk of being shown up by Lee...
See what I mean?
Another:
(defun c:dms (/ str tdef)
 (setq str "")
 (while (setq tdef (tblnext "LAYER" (not tdef)))
   (if (minusp (cdr (assoc 62 tdef)))
     (setq str (strcat str (chr 44) (cdr (assoc 2 tdef))))))
 (sssetfirst nil (ssget "_X" (list (cons 0 "DIMENSION")
                                     (cons -4 "<NOT")
                                       (cons 8 (substr str 2))
                                     (cons -4 "NOT>"))))
 (princ))
See what I mean?
Sorry dude :wink:
