student21 Posted February 15, 2010 Posted February 15, 2010 Need help, I found this program that does pretty much what I need it to do, but I would like it to use the current text style instead of using "standard" and more importantly I need it to put the text at the "midpoint" of the line or lines either above or below. Thank you much (defun c:LINELENGTH ( / CONST_STYLE CONST_TXT-HT CONT COUNT DIST ENT IP LAYER ROT SS) (if (setq ss (ssget)) (progn (setq count 0) (repeat (sslength ss) (setq cont (entget (ssname ss count))) (if (= "LINE" (cdr (assoc 0 cont))) (progn (setq CONST_txt-ht 1.0 CONST_style "LY080" layer (cdr (assoc 8 cont)) ip (cdr (assoc 10 cont)) rot (angle (cdr (assoc 10 cont)) (cdr (assoc 11 cont))) dist (distance (cdr (assoc 10 cont)) (cdr (assoc 11 cont))) ent (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 8 layer) (cons 100 "AcDbMText") (cons 10 ip) (cons 40 CONST_txt-ht) (cons 41 dist) (cons 71 7) (cons 72 5) (cons 1 (rtos dist 2)) (cons 7 CONST_style) (list 210 0.0 0.0 1.0) (cons 11 (cdr (assoc 11 cont))) (cons 50 rot) (cons 73 1) (cons 44 1.0) ) ) (entmake ent) ) ) (setq count (1+ count)) ) ) ) ) Quote
lpseifert Posted February 15, 2010 Posted February 15, 2010 Are you interested in learning how to edit the code or is this a request for someone to do it for you? Quote
student21 Posted February 16, 2010 Author Posted February 16, 2010 Preferably I would want someone to code it for me. If that is possible. Thanks Quote
