doGnation1 Posted February 15, 2010 Posted February 15, 2010 Hi: Can you change a .pdf file into an AutoCad format (.dwg)? Any help is greatly appreciated. God Bless, chris Quote
NBC Posted February 15, 2010 Posted February 15, 2010 It's only worthwhile, however, if the pdf was created by using a program that exported the pdf from vectors Quote
JD Mather Posted February 15, 2010 Posted February 15, 2010 Probably the best method is to contact the owner of the Intellectual Property and request a dwg file. Quote
ServaCleanCAD Posted February 15, 2010 Posted February 15, 2010 I use a program called PDF2DWG (Google it). Not bad results, plenty of options to get the resultant DWG pretty good. You can use the program FOC for 300 runs before you need to buy it. Quote
doGnation1 Posted February 15, 2010 Author Posted February 15, 2010 Thanks everyone for your help! chris Quote
