CadMunkee Posted August 18, 2008 Posted August 18, 2008 Hey guys. I've been successfully using SSM until we recently upgraded our system to 2009. I've been having some pretty significant problems getting Sheet Set Manager to print my drawings. When I select my drawings from the sheet set list and 'right click', in order to bring up the plot override dialogue box we use to retain our print settings for different sheet sizes, and .pdf page set ups, the box takes a VERY long time to come up and respond. The system can sometimes get as far as printing the first selected drawing, and seems to lose the data after that. Has anyone experienced this before? I can send a bunch of .dwf files without issues, and also do not have a problem sending .pdf files. I previously thought it might be a memory issue. . but now I'm not sure. So to circumvent my issue I'm using publish to print a .dwf list, then sending to plot. But SSM is so much better in that it is constantly current. Using publish I have to continually update my current .dwf file. . Any help would be greatly appreciated! Quote
sparklerach Posted August 18, 2008 Posted August 18, 2008 Hi There, We don't use sheet set manager but we upgraded to 2009 and had some minor problems. We found the 2009 update and once installed, all the minor problems were fixed. So if you haven't already installed the 2009 update, maybe this can fix your problem. Hope this helps. Quote
CadMunkee Posted August 18, 2008 Author Posted August 18, 2008 Great! I'll see how I go with the update. . I tried downloading it a while ago, but found that it wouldn't install properly, it's probably a security setting on my machine, me not being the administrator an all. Thanks for the heads up, it's on the autodesk support site, no? Quote
