KRBeckman Posted February 17, 2010 Posted February 17, 2010 Is there a way to have a line connect the last point selected with the current location of the mouse when you're picking points while in a lisp routine? Kinda like when you're drawing a line there's a line (I think I've seen this called a "Rubberband") between the last selected point and where the mouse is currently located. Quote
Lee Mac Posted February 17, 2010 Posted February 17, 2010 Something like? (setq p1 (getpoint "\nPt: ") p2 (getpoint "\nPt: " p1)) Quote
KRBeckman Posted February 17, 2010 Author Posted February 17, 2010 Can this be taken further? If there are 4 points being selected, and have a line connecting point 1 to 2, 2 to 3, and 3 to 4? Quote
Lee Mac Posted February 17, 2010 Posted February 17, 2010 You might have to look into grvecs/grdraw for that Quote
The Buzzard Posted February 17, 2010 Posted February 17, 2010 Can this be taken further? If there are 4 points being selected, and have a line connecting point 1 to 2, 2 to 3, and 3 to 4? Try this: (defun C:DL (/ PT01 PT02) (setq PT01 (getpoint "\nSpecify line starting point: ")) (while (/= nil (setq PT02 (getpoint PT01 "\nSpecify line ending point: "))) (command "._line" PT01 PT02 "") (setq PT01 PT02)) (princ)) Quote
Lee Mac Posted February 17, 2010 Posted February 17, 2010 Another Example: (defun c:test (/ GetPoints LWPoly lst) (defun GetPoints (str1 str2 / pts pt) ;; Lee Mac ~ 17.02.10 (if (car (setq pts (list (getpoint str1)))) (while (setq pt (getpoint str2 (car pts))) (mapcar (function (lambda (from to) (grdraw from to 3 0))) (reverse (cdr (setq pts (cons pt pts)))) (cdr (reverse pts))))) (redraw) (reverse pts)) (defun LWPoly (lst cls) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 90 (length lst)) (cons 70 cls)) (mapcar (function (lambda (p) (cons 10 p))) lst)))) (and (setq lst (GetPoints "\nSelect First Point: " "\nNext Point: ")) (LWPoly lst 0)) (princ)) Quote
