fbby Posted February 18, 2010 Posted February 18, 2010 Helo everyone, Can anyone help me on the dimension of this drawing because when I making the dim it will explode automatically when I Enter? I need to change the settings of this because if I going to change the distance I will ERASE first then again I will make dimension can anyone help me on this? I appreciate any suggestions thanks ___________________________ sorry for my english Dim.dwg Quote
Tiger Posted February 18, 2010 Posted February 18, 2010 change the variable DIMASSOC to 1 or 2 (type DIMASSOC on the commandline) - from Help: DIMASSOC (Quick Reference) Controls the associativity of dimension objects and whether dimensions are exploded. 0 Creates exploded dimensions. There is no association between the various elements of the dimension. The lines, arcs, arrowheads, and text of a dimension are drawn as separate objects. 1 Creates non-associative dimension objects. The elements of the dimension are formed into a single object. If one of the definition points of the dimension moves, the dimension is updated. 2 Creates associative dimension objects. The elements of the dimension are formed into a single object, and one or more definition points of the dimension are coupled with association points on geometric objects. If the association point on the geometric object moves, the dimension location, orientation, and value are updated. Quote
fbby Posted February 18, 2010 Author Posted February 18, 2010 thanks a lot ___________________________ sorry for my english Quote
