dmj77 Posted February 23, 2010 Posted February 23, 2010 Hi, how can I permanently turn off block authoring palettes in block editor? Every time when I edit block I must turn off block authoring palettes. That really irritates me. Thanks Quote
Fire_col Posted February 23, 2010 Posted February 23, 2010 I agree it is totally irritating! Unless there's something specific that you are doing with your blocks then why not just edit them in place? That's what I do. The other option is just to set the palette to autohide and, as you would with a window, make it as small as it will go and place it on the upper left hand corner of your window just far enough away to prevent docking. It still means you've got a grey bar on your screen but it's less obstrusive and will remain as you've left it. If you do find a way to turn it off let me know! Quote
dmj77 Posted February 23, 2010 Author Posted February 23, 2010 Allow Docking, Anchor Right - I didn’t remember that - Thank you If I find some way to turn it off I let you know. How you edit them in place? I using double click on block when I want to change something Quote
Fire_col Posted February 23, 2010 Posted February 23, 2010 Select the block you wish to edit> right click> on the menu select 'Edit Block In-Place' Quote
BearDyugin Posted February 23, 2010 Posted February 23, 2010 There are two variants 1) Need the big monitor CUI-> Ribbon-> Contextual Tab States-> Mode blocks editor -> Contextual Tab " Blocks editor " -> General -> Type of contextual display -> United 2) Cardinal CUI-> Ribbon-> Contextual Tab States-> Mode blocks editor -> delete Contextual Tab " Blocks editor " (Translate can be not exact, look on sense) Quote
dmj77 Posted February 24, 2010 Author Posted February 24, 2010 Select the block you wish to edit> right click> on the menu select 'Edit Block In-Place' I didn't know that way bat is not bad at all. Thanks To Geobuilder: CUI-> Ribbon-> Contextual Tab States-> Mode blocks editor -> Contextual Tab " Blocks editor " -> General -> Type of contextual display -> United I have Full and Merged instead United and with Merged I do not get what I want. Anyway when I do Allow Docking, Anchor Right is not bother me any more. Thanks anyway Quote
Guest bmn123 Posted May 18, 2010 Posted May 18, 2010 how to use the block authoring palettes in autocad Quote
