salmonrose Posted February 23, 2010 Posted February 23, 2010 I'm working on a client's drawing and needs to add some pline on Layer 0. When I draw new pline, the line width is set to 1. How can I change it back to 0 before drawing them? I want to aviod changing the width after drawing the pline since it is time consuming. Thanks. Quote
rkmcswain Posted February 23, 2010 Posted February 23, 2010 The system variable PLINEWID controls default polyline width. You can also set the width when you start the ._PLINE command. (._PLINE;;_W;) Quote
