Shandley Posted February 23, 2010 Posted February 23, 2010 Greetings, I am not what you would call a noob but I am self taught. This being said, I have been playing with Autocad for about 8 years now and I use it daily at work. I am trying to explode some text using txtexp. When I do that, it does explode but it scales it to just over 1/25th the size and sends it off to the upper right of the screen. This doesn't happen EVERY time but there is no rhyme or reason to it. I tired Autocad 2004, 2006, and 2007. I tried individual texts and multiple. Here is a couple photos of the issue: BEFORE AFTER - You can see the text in the upper right corner as a bit of a white blur Quote
lpseifert Posted February 23, 2010 Posted February 23, 2010 Is the font you are using a .ttf? Txtexp doesn't play well with .ttf fonts, especially if it is mtext. Quote
Shandley Posted February 23, 2010 Author Posted February 23, 2010 Is the text annotative? Pardon my ignorance but what is that? Quote
alanjt Posted February 23, 2010 Posted February 23, 2010 Pardon my ignorance but what is that? Pardoned. Command: 7 LIST 1 found MTEXT Layer: "0" Space: Model space Handle = 45299 Style = "EXISTING" Annotative: Yes [color=Red]Annotative scale: 1" = 100'[/color] Location: X= -3983.37 Y= 2682.91 Z= 0.00 Width: 0.00 Normal: X= 0.00 Y= 0.00 Z= 1.00 Rotation: 0d0'0" Paper text height: 0.08 Model text height: 8.00 Line spacing: Multiple (1.000000x = 0.13) Attachment: TopLeft Flow direction: ByStyle Contents: text Quote
Shandley Posted February 23, 2010 Author Posted February 23, 2010 I do not think so. list 1 found MTEXT Layer: "0" Space: Model space Handle = cb Location: X= 11.9031 Y= 17.6513 Z= 0.0000 Width: 2.0000 Normal: X= 0.0000 Y= 0.0000 Z= 1.0000 Rotation: 0 Text style: "Standard" Text height: 0.1750 Line spacing: Multiple (1.000000x = 0.2917) Attachment: MiddleCenter Flow direction: ByStyle Contents: {\fSwis721 BdRnd BT|b0|i0|c0|p34;HOUSE BATTERY\PVOLTS} Quote
alanjt Posted February 23, 2010 Posted February 23, 2010 I do not think so. list 1 found MTEXT Layer: "0" Space: Model space Handle = cb Location: X= 11.9031 Y= 17.6513 Z= 0.0000 Width: 2.0000 Normal: X= 0.0000 Y= 0.0000 Z= 1.0000 Rotation: 0 Text style: "Standard" Text height: 0.1750 Line spacing: Multiple (1.000000x = 0.2917) Attachment: MiddleCenter Flow direction: ByStyle Contents: {\fSwis721 BdRnd BT|b0|i0|c0|p34;HOUSE BATTERY\PVOLTS} It's not. Doh, I didn't even pay attention to what version you were running. I'm dumb. Could you get away with exploding the text the executing TXTEXP? Quote
Shandley Posted February 23, 2010 Author Posted February 23, 2010 Thats what I used. I tried just x and I tried the Express, Text, Explode Text (which I think is the same as TXTEXP) Quote
alanjt Posted February 23, 2010 Posted February 23, 2010 Thats what I used. I tried just x and I tried the Express, Text, Explode Text (which I think is the same as TXTEXP) No, I mean to just EXPLODE the MText first (becomes Text). Then TXTEXP them. Quote
Shandley Posted February 23, 2010 Author Posted February 23, 2010 Ok, when I EXPLODE the MText, it turns it into the Standard style. I changed the style to the font I want and used the TXTEXP command but it does the exact same thing. Quote
