AutoCAD mulitiple drawing files printer change
Hi,
I was using the AutoCAD 2006, in that whenever we create the CAD drawing file we will use the template which will defined with particular printer/plotter. Hence all the drawings files have their default printer/plotter within drawing file itself. So if we give ctrl+p, then it is getting printed with the printer which configured internaly with the drawings.
Now i have moved AutoCAD to different server with AutoCAD 2010 map version. Hence the previous network printer/plotter are not available. If w open the drawings and give ctrl+p , it is showing the error that the printer/plotter is not available. How to make the chnage for all the drawing files to refer the network printers.
I am very new to AutoCAD softwrae itself, i am involing this migration work. Could you please assist me on this.
Regards,
Ganapathy.S
ganapathy1323@gmail.com
