h_r_sh Posted February 23, 2010 Posted February 23, 2010 Hi all. I have installed acad2010 and it works. Now when I want to launch, splash screen will be appeared for one moment and hide and program will be closed. Please help me on this. Regards Quote
ReMark Posted February 23, 2010 Posted February 23, 2010 Is it the 32-bit or 64-bit version? What OS are you using? Is it a 32-bit or 64-bit version? What are the hardware specs? Did you have a previous version of AutoCAD running on this system prior to loading AutoCAD 2010? Did you encounter any problems during the installation of AutoCAD? Quote
h_r_sh Posted February 23, 2010 Author Posted February 23, 2010 Is it the 32-bit or 64-bit version? What OS are you using? Is it a 32-bit or 64-bit version? What are the hardware specs? Did you have a previous version of AutoCAD running on this system prior to loading AutoCAD 2010? Did you encounter any problems during the installation of AutoCAD? It is the 32-bit version, I use Windows XP SP2 32-bit, 4 GB of RAM, 500 GB of Hard, Asus P5Q Pro M.B. 3.0 GHz, ATI Radeon HD with 1.0 GB of RAM, I have ACAD2008 and 2009 and these versions are runing with any problem, No, any problems. My ACAD 2010 was working but today, I don't know what is going on. May you please help me to fix it? Quote
ReMark Posted February 23, 2010 Posted February 23, 2010 It was working at some point and then stopped working. Seems very strange. Since the problem occurred have you tried shutting down the computer and restarting? Quote
h_r_sh Posted February 23, 2010 Author Posted February 23, 2010 It was working at some point and then stopped working. Seems very strange. Since the problem occurred have you tried shutting down the computer and restarting? Yes, I restart the PC for afew times, but nothing changed.... Quote
ReMark Posted February 23, 2010 Posted February 23, 2010 You could try the REPAIR option found in Add/Remove Programs. Quote
ReMark Posted February 23, 2010 Posted February 23, 2010 By the way, did you ever download and install Update 1 for AutoCAD 2010? You might try that first. Quote
