P_c Posted March 1, 2010 Posted March 1, 2010 Gday, Has anybody else found that when you use the layer isolate tool that gradient hatches do not fade. They still lock and are not editable, but they just dont fade. Is this a common thing or is it just me? If so, is there a fix. Cheers Quote
edwinprakoso Posted March 2, 2010 Posted March 2, 2010 Gday, Has anybody else found that when you use the layer isolate tool that gradient hatches do not fade. They still lock and are not editable, but they just dont fade. Is this a common thing or is it just me? If so, is there a fix. Cheers What is the Fade value? Try to change it to smaller value. Command: layiso Current setting: Lock layers, Fade=78 Select objects on the layer(s) to be isolated or [settings]: s Enter setting for layers not isolated [Off/Lock and fade] : Enter fade value (0-90) : 50 Quote
P_c Posted March 2, 2010 Author Posted March 2, 2010 Fade level does not make any difference. I have also checked with other people at work and the same thing happens to them. Quote
